跳转到主内容
加入维修社区 - 创建账户
发布于 2019 年 4 月。型号:A705FN/DS
doesn't work sound
when using the earphone and calling someone the sound system doesn't working just silent the whole sound
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
@shimek does that happen when you plug the earphone into the jack or when does it happen? Explain exactly what you are doing. This could be a settings issue or a jack issue.
由完成的 分享
@oldturkey03 when am using the phone by earphone ,and if somebody calling to my phone will be silent
由完成的 分享
@shimek but it works okay when you use it without the earphone?
由完成的 分享
@oldturkey03 yes that good
由完成的 分享
@shimekeleme sounds like a bad headphone jack. Let's see if this is replaceable as a part.
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
@shimekeleme this sounds like your phone is having issues with the headphone jack. That jack is soldered to the daughterboard (charging board). I would suggest that you replace that board and then re-evaluate if it works. If not then the issue could be on the main circuit board.
Since iFixit does not yet have a specific guide for this, use the one from here It is written in Spanish so use a browser that will do the translating for you, if needed. Replacement boards are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Hafiz Keleme 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 294
