跳转到主内容
Repair guides and support for external portable storage by Western Digital including the My Book series, My Passport and others.
218 个问题 查看全部
Can you replace the circuit boards on an external hard drive?
I accidentally plugged in my laptop power cable to my WD external hard drive and basically fried the power source.
I placed the hard drive in a separate external case and when I tried to power it on nothing happened, but when I unplugged the hard drive from the external case the case lit up and the fan turned on instantly. I don't have any testing equipment out here, but I did notice a lot of the circuit board had burn spots most likely where it was also fried once the power adapter was removed. Is there any way to salvage the drive or replace the parts? I'm not educated in the arts of soldering either so sadly that's a no go as well.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Ok, so I looked at the model number and it's WD30EZRS - 00J99B0 would that PCB still work with that model?
完成的
Gary, yes it will. "WD30EZRS-11J99B0 » WD30EZRS-11J99B0 2060-771698-002 REV P2 PCB."
完成的
Alright cool thanks a lot!
完成的
添加一条评论
3个答案
已选择的解决方案
Gary, the only thing that you could try is to get a PCB from the same model and replace it. This may enable you to access your drive. However, the larger drives do have some issues with that. If it is important data that you have on the drive, you may consider a data recovery service$$$ or some electronic repair shop that might fix it for you $$. There is some great discussion about an issue like that on here. Hope this helps, good luck.
这个答案有帮助吗?
得分 3
6条评论:
Thanks for the quick response! Do you know of any place I might be able to purchase one of those? I'm still rather new to the whole tinkering of electronics lol
完成的
Sorry I have switched it to an answer due to more information. Anyhow, what is the exact model of your drive? We might find something that will help you out.
完成的
here is one board that I found. It is meant for data recovery. Check it out right here and it is for these drives WD30EZRS-11J99B0 » WD30EZRS-11J99B0 2060-771698-002 REV P2 PCB. not cheap....;)
完成的
It's a caviar green but the exact model number I can't get until after work.
完成的
sounds good, just let us know and I am sure that by that time, someone else might have another idea. Don't work to hard :)
完成的
显示更多的1条评论
添加一条评论
i found one for you at http://pcb-hdd.com/wd30ezrs-11j99b0-2060...
这个答案有帮助吗?
得分 1
添加一条评论
http://www.hddzone.com/wd-2060771698002-...
I found this pcb supplier, cheaper with free shipping.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Gary 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 12,179
