跳转到主内容
加入维修社区 - 创建账户
这款 HP 机型发布于 2012 年。升级配置包括 15.6 英寸防眩光屏幕和指纹识别器。
Battery in not charging
I used windows 10. Then it was showing plugged in (not charging) now i was installed windows 11. Now its not showing (not charging) but it was stucked at 1%. I was using my laptop with only ac adapter
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If a device is plugged in but not charging, there are several possible reasons, including:
  • Your charging cable could be loose, unplugged, or damaged.
  • Your charging cable could have a weak connection because it wasn't made by your laptop's manufacturer.
  • Your charging ports could be clogged with dirt or debris that is keeping it from powering up properly.
Here are some things to try:
  • Check the connection: Unplug the charger from the device and the wall outlet, inspect the connection points for damage or debris, and reconnect the charger.
  • Check the outlet: Plug another device into the outlet to confirm it's working.
  • Try a different cable or charger: If possible, try using a different USB cable or charger.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sabastin Cruzz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 311
