@devanshu92258 are you saying that your TV does not turn on, no matter which button you push? Dud you check the electrical outlet where it is plugged in to? You have checked the power cord? Does the power LED turn on? Does your TV show any sign of live?
由 oldturkey03 完成的
I have the same problem, no red LED when it is plugged in and the power supply circuit seems intact
由 Nicolas El Reda 完成的
@nicolaselreda
What is the model number of the TV?
Did you check if the fuse on the power board in the TV is electrically OK by testing it with a DMM (digital multimeter)?
由 jayeff 完成的
