跳转到主内容
加入维修社区 - 创建账户
1620 万像素 Exmor R CMOS 数码相机,配备 3.5 英寸 OLED 触摸屏、3D 全景扫描和全高清 1080/60p 视频录制(黑色) 发布日期:2011 年 1 月 12 日
Why is my camera don't on while charging
My camera don't on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@harsh56452 first you want to check your AC adapter. Make sure it has the proper voltage. Check to make sure the connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working. If all of that checks out, you do want to go ahead and replace the battery. A depleted battery can no longer be charged and can possibly prevent the camera from coming on.
After that you will have to disassemble your camera and check the power circuitry on your camera. On your cameras SY-280 board are two fuses, marked F051 and F051. Those are the power supply fuses. Check those for continuity. If they have failed, your camera will not come on.
You can now get the service manual on the bottom of this page Sony Cyber-shot DSC-TX100V Check under documents.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harsh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 230
