跳转到主内容
The JBL Flip 6 is a small portable Bluetooth speaker, released in September 2021. It is equipped with a woofer and a separate tweeter, and dual JBL bass radiators. This Speaker comes with an IP67 and up to 12 hour battery life.
No response from the speaker unless unplug battery
No response from speaker opened it up unplugged the battery then plugged it in then you hear the pairing noise Bluetooth flashes then cuts out and won’t charge or respond unless you do it again but same thing happens can’t find any short unplugged everything on the board then plugged back in
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Replace the battery
这个答案有帮助吗?
得分 0
1条评论:
I tried that did not work
完成的
添加一条评论
添加你的答案
Josh Fron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 32
