跳转到主内容
加入维修社区 - 创建账户
Xbox 360 是微软于2005年11月22日推出的第二代电视游戏主机。
My disk drive's laser lights up but does not recognize disks
When I insert a CD or DVD, the laser lights up, but it does not read the disk. Can I adjust the potentiometer, and if so, how?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@daneelliottd532 if it does not read any CD/DVD/ or game disk, it is unlikely that adjusting the Pot's will fix this. It does sound like a bad laser. Have you cleaned the laser lens already? I'd start with that.
Now, if you are really thinking that a Pot adjustment will make a difference, use this XBOX 360 POT CALIBRATION Do this with care since you are running risk of burning out your laser if done wrong.
这个答案有帮助吗?
得分 1
9条评论:
I cleaned it with a dry Q-tip and is still does not recognize my music CD. :( I'll try to see if the pots need adjustment.
完成的
@daneelliottd532 careful with that. POTS should never "need" adjustment. All they are doing is controlling the voltage to your Laser. As the laser ages the adjustment can help, but it can also burn out your laser if not done right.
完成的
@oldturkey03 I've found a good replacement laser on eBay. I'll look into buying it.
完成的
I found a what looks like a bulging capacitor. I’ll add a pic onto the post
完成的
@daneelliottd532 sure does look like it's bulging a bit. Time to replace it.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Dane Elliott-Dyson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 244
