跳转到主内容
加入维修社区 - 创建账户
Xbox 360 是微软于2005年11月22日推出的第二代电视游戏主机。
How to fix "unrecognized disk"
this just happened to me today. i opened it and cleaned it out and it still wont work. every time i put a disk in, it says unrecognized disk. i want to fix it but i already fixed it for red rings so I don't want to put anymore money into it. besides ps3 (even ps2) is better than xbox!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
when you say cleaned it out, what did you clean out?
完成的
添加一条评论
2个答案
已选择的解决方案
Zane, the first thing I would suggest is that you clean the laser. you can purchase a DVD cleaning kit at most department stored. Should you have no luck finding one, you ill have to disassemble your optical drive. Here is how to get it out, and on here you can see how to disassemble the individual drive. Make sure you select the right optical drive, there are a few different ones. Once cleaned you can try it and see what happens. If the cleaning did not help, you can try a Pot adjustment. Great instructions are downloadable from here. Be sensible with the adjustment. If you are not up to that, you can of course also replace the laser assemble, or the whole drive. Just remember that "Xbox 360 is designed so that the DVD drive works only with the particular game console it is installed in". So you will have to reflash it or keep your original PCB and replace your drive with the same model, and switch the PCB over. Hope this helps, good luck
这个答案有帮助吗?
得分 1
1条评论:
I brought a cleaning DVD for my.Xbox and it doesn't read and my black ops 3 doesn't read ether
完成的
添加一条评论
&&^& you @%^$$@$# all of you
这个答案有帮助吗?
得分 0
1条评论:
Your &&^&^$^ shyts broke you got it good go cry and die or buy my product u son of a ##&&%
完成的
添加一条评论
添加你的答案
Zane 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 15,016
