跳转到主内容
The twelfth and final generation of the Cadillac Eldorado was introduced in 1992 as a two-door coupé.
intermittently operating turn signals
1996 Caddy. Turn signals will operate intermittently. Sometimes I get one flash, sometimes none, a minute later they are working just fine. All bulbs appear to be working. I prefer problems that are all or none, this lazy light stuff drives me nuts. I think to problem may be with the flasher but have no idea of how to fix it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
I'd go with the turn signal relay. It's one of the easier things to start with. It could just be sticking :-) It is located below the Instrument Panel, left of the Steering Column.
Removal Procedure
1. Remove the left closeout/insulator panel. A small 7mm bolt is holding it in place.
2. Disengage the turn signal flasher from the upper instrument panel carrier assembly.
3. Disconnect the electrical connector.
4. Remove the turn signal flasher.
Installation Procedure
1. Connect the electrical connector to the turn signal flasher.
2. Position the turn signal flasher into the slot in the instrument panel carrier assembly.
3. Slide the flasher upward in order to secure the retainer clip to the carrier assembly.
4. Install the left closeout/insulator panel.
the relay is available right here.
这个答案有帮助吗?
得分 3
2条评论:
Problem fixed. It was actually a loose wire connection to the relay.
完成的
Excellent, good fix. Thank you for accepting my answer.
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 6,698
