跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Bluetooth and Wifi working without Airport/Bluetooth Board connected?
Not to look a gift horse in the mouth, but.....
I was recently repairing something else and found myself (disabled, low vision, low dexterity, tremor) having to reconnect the wretched little antenna cable connectors to the Bluetooth board. After about 4 hours of continuous work, realizing the futility of this, I gave up and left the cables disconnected, assuming I'd have to buy a USB adapter to replace the Wi-Fi/Bluetooth functions.
But....... My Wi-Fi and Bluetooth are working fine without them.
What's going on there? What do the antennae cables really do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The logic board connector presently is the antenna! That little pin point in the middle. The wire connects to a much larger exposed metal piece which is fully exposed outside of your metal case.
So while it appears to work the AirPort board is now being stressed over time it will fail in this state as the expected load is missing.
Best to find a friend to help you being care full not damaging the connector or cable.
这个答案有帮助吗?
得分 1
1条评论:
That makes sense - thank you! I plan to have it fixed soon.
完成的
添加一条评论
添加你的答案
biterate 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 29
