Stuck in bios settings
My laptop is just stuck in bios setting every time i switched on, how can i fix it so that when i switch on it should boot and not stuck in bios setting?
You are already in the BIOS Settings but for others press F2 after powering on.
Stuck in BIOS? It is likely trying to tell you something.
When you click "Boot" on the menu does your boot drive show in the Boot Menu list?
Under [Boot Priority Order] there should be SATA SSD or SATA HDD.
Either of those should be at the top of the list. F6 moves them up or down and F10 saves the settings.
Let us know what you find so we can help you further, if needed.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 32
总计 211
