跳转到主内容
加入维修社区 - 创建账户
PSP E1000 是一款索尼设计并生产的掌上游戏机。也被称为 PSP Street,这是 PSP 的廉价机型,于 2011 年 10 月发布。
Is my device bricked?
So, I was opening my PSP Street wide to get something stuck in the SD slot out, and I unplugged the LCD: And when I put it back the video output was fine at first but after some on/off it showed a white screen. I tried unplugging it and plugging it back and turns out I plugged it in loosely. However after a very short duration the screen gradually turned white, so I plugged it out.
Next thing I know the PSP has turned off and not only the battery stopped working altogether, but the display didn't show anything anymore.
Is it bricked? or can I somehow, by a miracle, fix it?
EDIT: Turns out the battery is fine, I somehow managed to plug it in in a way that it unplugs itself when I put the lid back on and pick the device up. 🤦‍♂️
Anyways, the screen remains an issue. I can see it changing brightness very slightly when I turn on the PSP, and nothing on the display itself seems damaged; But it shows a completely black screen. I've tried to shine a bright flashlight on it, but not much of a signal can be seen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi! White screens usually indicates that the cable isn’t connected properly or is damaged. Won’t your PSP not turning on anymore?? Or does it turn on at the moment?
Update (08/10/24)
Yeah, you probably need a new screen. The ribbon cable is probably damaged. I would try this first and see how it goes!
这个答案有帮助吗?
得分 2
9条评论:
Turns out, the battery was just loosely plugged in. it can actually turn on without AC, but that still doesn't fix the screen issue. It's completely black, but it actually turns on and I can see it slightly changing brightness. I don't know if the display is fried or the device is bricked.
由完成的 分享
I probably can't get an exact replacement, what are the general specs I'm looking for?
由完成的 分享
Hi!
You need this one: https://www.aliexpress.com/i/10050052268...
They do ship worldwide!
由完成的 分享
@dan0 "This item is no longer available".
由完成的 分享
Then you need this one: https://www.googleadservices.com/pagead/...
The screen is expensive :(.
由完成的 分享
显示更多的4条评论
添加一条评论
添加你的答案
Zero 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 38
总计 1,033
