跳转到主内容
加入维修社区 - 创建账户
Xbox Elite 无线控制器 Series 2 于 2019 年 11 月 4 日发布,兼容 Xbox One、X 及 S 系列主机,以及运行 Windows 10/11 的个人电脑。型号 1797。
Non-responsive with battery connected
Have a strange issue. My elite 2 controller is completely non-responsive when the battery is connected. Won't power on, charge, or anything. BUT it works when plugged in via usb without the battery connected. As soon as I reassemble the back plate and connect the battery, the controller is completely dead.
Useful diagnostic info:
  • battery is delivering power and not damaged
  • no liquid damage to controller
  • no visible corrosion on battery connectors
What is going on????
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Are you using a battery pack? Or just 2 AA batteries? Did you tried both to test the controller? Is the controller up to date? When using a battery pack, which brand? The one from Microsoft?
由完成的
This is an elite series 2...the battery is built-in, not AA replaceable. The battery is original.
由完成的
添加一条评论
2个答案
最有帮助的答案
Hi Matthew! Sry! Okay the easiest thing to try is a new battery pack and see if that solves it! If not, it’s motherboard related. Controller is up to date?
这个答案有帮助吗?
得分 1
2条评论:
The controller is up to date. I just put the controller back together and while securing the back plate onto the board housing the controller turned on. Once I screwed the back plate onto the housing completely, the controller is now no longer responsive. Could there be a faulty or loose connection? The three pin battery terminal doesn't appear damaged.
Thoughts?
由完成的
Hi! Could be, or something is causing a short. Can you check if the screws are not touching the motherboard? Also check the cables to see if they are free when closing the back plate.
由完成的
添加一条评论
Its possible you are screwing the screws too tightly wgen you reassemble the controller. Try to loosen them a little. It might work
这个答案有帮助吗?
得分 0
1条评论:
Any fix? I have one with the same problem
由完成的
添加一条评论
添加你的答案
Matthew Riordan 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 63
总计 592
