跳转到主内容
Removing scratches from the back?
I got a iPod nano for 10$ and it does work, but it is scratched up like mad on the back
Is there anything i can try to to remove some, if not all of the scratches?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Nick, what I do with the older back plates is to use some buffing compound and a buffing wheel. This usually removes most scratches Depending on how deep they are). Your Nano is a bit small and tough to hang on to, so be careful if you use a wheel. Otherwise you will have to buff it by hand. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
5条评论:
Most of them are the light ones that are pretty typical on shiny back iPods, a few lighrt scratches
完成的
Yes, they should buff out.
完成的
i'll have to try it and get a case to avoid this again, although it's commonplace, i do want to keep it minimal
完成的
Thanks for accepting my answer. Yes, a case would be good, since they do get banged up quite a bit. Good Luck.
完成的
this one has dings on the faceplate from being dropped, and scratches too, pretty clear old owner, who was a friend never used a case
完成的
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 1,646
