跳转到主内容
Repair guides and support for the Lenovo Ideapad 310-15IKB, a midrange consumer laptop released in 2016.
Backlight not working even after screen replacement.
Hello,
I spilled coffee on my laptop. I got the laptop back running normally after unplugging the dock connector and it worked fine for a long time. But the coffee also got into the screen and it was driving me crazy. I decided to try to fix the screen by taking it apart and wiping the coffee away. When I plugged the screen back, the backlight wasn't working. I ordered a new screen and I got the same issue. I think it might be an issue with the motherboard. The old display could short the circuit. Where are the backlight fuses located?
Thanks for help, Jacob
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
To locate the backlight fuses on your Lenovo IdeaPad 310-15IKB inspect the motherboard, particularly near the LCD connector, for small surface-mounted fuses. Use a multimeter to test these fuses for continuity.
这个答案有帮助吗?
得分 0
2条评论:
ye i cant click links, my mom disabled it
完成的
添加一条评论
添加你的答案
Jakub Chmelař 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 89
