跳转到主内容
加入维修社区 - 创建账户
佳能 PIXMA G3010 是一款于 2018 年初发布的多功能一体化无线 MegaTank 打印机。它支持打印、扫描和复印,内置 Wi-Fi 和直接无线连接功能,可轻松实现移动打印。
How to fix P22 error
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
How to fix p03 error
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
P22 is a somewhat vague error :-(. It's a mechanical error in this case, but a lot of the time it's a damaged scanner. SOMETIMES it can be fixed by reseating the scanner cables. I don't have a G3010 to show the process on, but I did find a video that shows how to open the unit up and check the cables.
If reseating the cables does not help, you will need to replace the scanner assembly. Canon does not directly sell parts for ANYTHING they sell, so you need to go through a 3rd party to get the part if it is even available. Given this is an inkjet and the CISS inkjets are just more expensive disposable hardware (whereas cartridge-based units were cheap, but ink was expensive), parts may not be readily available. Your best bet would be getting a donor printer with the infamous 5B00 error (commonly used waste ink error code, which might vary) to get the part off. I say this because you can't fix that issue without rerouting the waste ink or a full teardown and making an absolute mess, so nobody wants to do it; 5B00 and it's equivalents are a death sentence. But this also means anything outside of the controller board and pads is fair game to pull as long as it doesn't hold waste ink.
这个答案有帮助吗?
得分 2
添加一条评论
Try resetting the printer, cleaning/reconnecting the scanner cable, or replacing the scanner unit.
这个答案有帮助吗?
得分 0
1条评论:
please input auth code to unlock
由完成的 分享
添加一条评论
添加你的答案
Yatogami 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 28
过去 30 天: 118
总计 2,941
