跳转到主内容
The Lenovo IdeaPad 3-15IGL05 is a 15.6-inch laptop manufactured by Lenovo. This page contains repair and service information related to the Lenovo IdeaPad 3-15IGL05.
3 个问题 查看全部
I am not able to turn my Lenovo ideaPad 3 on what should I do?
I am not able to turn my laptop on like when i shut down this laptop then when i try to turn it on like when i press power on button it doesnt start but when i charge it (even though it has full charging) for 30-40 mins then it turns on and then i use it for next 10-12 hours again shut down for 6-7 hours then it again dont start next time i try to start it what should i do ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@shreyashkande this all sounds like a bad battery. You did not tell us if this happens when you are using the AC adapter as well. There is also a chance that it does that because of a thermal shut down. It may get to hot. That would be the first step I'd check if it happens on AC power as well.
Use the Hardware Maintenance Manual to change the battery, clean the air inlets, the fan and consider replacing the thermal paste as well.
The only other thing I would do is to run the Windows Event viewer and see if it shows any other reason why it may shutdown.
如何涂散热膏
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shreyash Kande 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 6
过去 30 天: 6
总计 6
