跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Screen image jumping and flashing. Backlight OK
Hi guys, just got a MBP with this issue, image attached. laptop was working fine(according to the owner) but it was getting high temperature working with SeratoDj. The guy opened it and changed the thermal paste. after that computer powers on and no image.
He bring me the macbook and I disassembled it completely looking for something off, it was pretty dirty, I cleaned up and and change the thermal paste for other more appropriate. Now the macbook powers on and sends image signal to the screen, but the image is jumping continuedly and moving, showing only sections of the screen, that moves. The macbook works OK with an HDMI external monitor, I don't think is the screen for sure(it could be). No bumps nor hits on the screen. Logic board model is 820-00138-A, I look it up online and found some boardviews files but they are not the exact same as the board, pretty similar, but not the same. Don't know really where to look or test XD. thank you in advanced !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
What you are seeing is a T-CON board failure. The small circuit board which is dangling from the display if you took it off. Sadly, it’s time for a new display assembly.
If you have the deeper skills working with SMD devices you might be able to replace the damaged component on the board. Some are custom to Apple so not available.
这个答案有帮助吗?
得分 1
2条评论:
thank you Dan, you're fast!
完成的
@annielservitec - Just good timing😀
完成的
添加一条评论
添加你的答案
Luis Anniel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 34
