MBP 15" kernel panic, GPU error
Hi everyone, a friend had a MBP 15" A1286 Mid 2010 with sudden restarts and the report said something about kernel and GPU (honestly don't know how to read it), made some test to try get the computer working normal, searching about this issue found something about a common problem in this model with the graphics card and get solved with a patch, installed the patch as the instruction says (the "MBPMid2010-GPU-Fix-0.6.1" patch return a message saying that it was patched successfully), however, the problem continued with the only difference that now it takes longer for it to happen. Also tried different HDD with newer system (my friend was on Yosemite and made some test with High Sierra) and different RAM modules (same brand and speed), but the issue continued.
The logic conclusion I got was that it was a Logic Board issue and had to be replaced, so we bought a new one from eBay (good reputation, arrived in great condition also), when we received we also upgrade to an SSD and replaced the logic board. To our surprise, the problem persist even doing SMC, NVRAM and installing the patch again.
Honestly, I no longer know what can be causing this issue since almost everything inside is new, unless is a problem related with: display assembly, battery, ODD or top case (being the only things that remain the same). Anyone knows what can be causing this problem? Any help would be very appreciated
Results of from eTreCheck regarding the kernel panic message:
1条评论
Almost forgot to mention that also replace the HD data cable, but solved nothing
由 Alejandro Peñafiel 完成的
