My Samsung A 51 over heating when charging
Why is my phone heated while charging, the charger also gets hot
@seantrim2008 the charger could be getting hot because your phone is drawing a higher amount of amps. For now you want to consider replacing the battery. A failed battery can be the cause of that. The only other thing you do want to take a look at is your charging board and the charging port flex. Make sure those are properly connected, show no corrosion or tears.
Here are the iFixit guides for that 三星盖乐世 A51 电池更换
Samsung Galaxy A51, remplacement du PCB USB, jack et boutons
指南
难度:
中等
45 minutes - 2 hours
指南
难度:
困难
2 hours
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 8
