跳转到主内容
加入维修社区 - 创建账户
此款 Power Mac G4 采用镜像驱动器门设计。
FireWire Target Disk Mode Not Working?
Hello, recently, i bought a firewire 400 cable to connect my iBook G3 to my PowerMac G4 MDD, to transfer files too large to for my flash drive. The cable finally arrived today, and I set the iBook to restart into target disk mode in system preferences, and connected the cable to both computers, it rebooted, and showed a yellow firewire logo, on a blue screen. However, My Powermac G4 never found the iBook, I tried connecting the cable to both of the firewire ports on the Logic board, and the other two on my expansion card, but nothing, it couldn't find the iBook, not even in disk utility. I also tried putting the PowerMac into Target disk mode, and the iBook couldn't reconize it. I'm not too farmilier as to how to use target disk mode, but it seems i did everything right. I also tried removing the expansion card in the PMG4, but still nothing, I don't have any other devices to test the cable. I also have a couple other cards in the powermac (SCSI, Sound) should I remove those as well? Did I forget anything to get this too work?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
What Mac OS are you using on the computer you are trying to use as target?
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
Try starting the PowerBook up holding the "T" key instead of using system preferences. Boot the PowerBook first then the MDD.
这个答案有帮助吗?
得分 4
7条评论:
I tried that, but it still does this.
由完成的 分享
The cable has to be suspect. What you did should work.
由完成的 分享
Ok, thanks. i might test it with a meter to see if it is messed up.
由完成的 分享
Remember the machine that is trying to be used in target mode must be Mac OS X
由完成的 分享
The cable was bad, I just decided to pay an arm and a leg at Best Buy, and get a new one and now it works.
由完成的 分享
显示更多的2条评论
添加一条评论
添加你的答案
Chris Green 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 30
总计 6,393
