跳转到主内容
加入维修社区 - 创建账户
Oppo F5 于 2017 年 11 月发布,是首款采用 18:9 显示屏而非 16:9 显示屏的智能手机。尽管拥有 6.0 英寸的屏幕,但 F5 的机身宽度与 5.5 英寸 16:9 显示屏的设备相似。型号为 CPH1723 和 CPH1727。
How to fix the booting loop?
i just reset my phone and then the screen is not changing anymore i try to use the recovery mode but it didnt work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
@oldturkey03 the robot got my one of the comment and I am running low now. Please have look at it. Take it back, read it (as it is for you only) and then I will delete it
由完成的
添加一条评论
2个答案
Hey hi zyro, the only thing I can suggest you at this point is a hard reset.
To do a hard reset, following the given steps:
1) Shutdown your phone
2) Put it in recovery mode (I assume you know it because you saved you tried putting it in recovery mode)
3) Wipe data or just do a factory reset
4) Reboot the system
If Hard reset also does not work then it might be just software update, also try charging the battery for a while (irrespective of it showing a sign of charging or no, just put in the cable, turn on the charger and take it back off after 20mins)before attempting a hard reset.
Thank you for reading and have a gorgeous day =)
这个答案有帮助吗?
得分 0
添加一条评论
Well I will suggest you to checkout the following video:
https://www.youtube.com/watch?v=tHWQbbmi...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
zyro 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 40
总计 922
