跳转到主内容
加入维修社区 - 创建账户
Miyoo Mini是由Miyoo(乐米游)于2021年12月2日上市的一款开源掌机。Miyoo Mini极其小巧,您可以随时随地放入口袋中、或从口袋中拿出。 基础定价为269.00人民币。
Why is my screen black
i believe i miss up my miyoo mini it was in miyoo ui and i put a onoin os sd card with an update it install but the screen turn black it turns on i can here sounds still just i can see anything I tried putting the old sd car with ui in it nothing i turned it off and turn it off and on still nothing I know it is dumb but i didnt know this would happen. you think it is fix able
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
This is most likely an software issue.. So if I'm correct, it failed after you've tried to install a firmware update for this device?
If this is the case, the best thing to do is to contact Miyoo. You could replace the motherboard to fix it, but this will be expensive.
Hopefully Miyoo do have something to re-flash the device so that it can be used again instead of replacing the motherboard....
If you are wondering regarding the motherboard replacement, here is a video: https://www.youtube.com/watch?v=6R2h4kfW...
Please let us know how it goes!
这个答案有帮助吗?
得分 1
2条评论:
This is for the miyoo mini plushic i have the regular small one wh is the miyoo mini not the plus but thank you for your help
完成的
Hi! My pleasure! Is this the video for your model? https://www.youtube.com/watch?v=97kOOxP3...
Have a nice day!
完成的
添加一条评论
添加你的答案
Flux 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 42
总计 1,072
