跳转到主内容
Released August 2003. An expensive, but high-end laptop of its time.
Why won't it boot up
press on button. green light comes on, screen flashes (sometimes) then it's dead
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Anything happen to it? Do you get any sign of the POST? What have you tired so far to fix it? Have your tried an AC adapter?
完成的
i'm back on with the machine in question maybe graphics card? don't know alot, is there some diagnostics i could run through it?
完成的
添加一条评论
1个答案
最有帮助的答案
henge, you might want to check on here. Those Dells' are prone to failure, especially the hard drive. Check your RAM as well. Good Luck.
这个答案有帮助吗?
得分 3
4条评论:
came on after many attempts a month ago getting less reliable in switching on, runs great when its going but now it wont start. battery seems fine. thanks for takin the time.
完成的
Do any of your LED's come on or do they blink? Have you tried an external monitor to make sure that it is not just your LCD?
完成的
Here is the service manual for your computer http://www.elhvb.com/mobokive/edwin/lapt...
完成的
thanks for trying old turkey, I'll let it hibernate through summer and look for another.
完成的
添加一条评论
添加你的答案
henge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,378
