跳转到主内容
加入维修社区 - 创建账户
Nintendo DSi 是 Nintendo DS 产品线的第三款迭代机型,于2008年底在日本市场发布。
How to replace damaged inductors component?
Hello,
NDSi won't power on anymore.
After following tutorial available to open NDSi, I have discovered damaged inductors located near Power connector from Power board. There are 4 inductors but 2 of them are damaged (pictures are available in case).
In order to replace them, seems Murata 1210 cms inductors, I need to get inductor characteristics.
Even if I know the answer, I have send an email to nintendo to obtain values, without any answer...
Hence, do you have an idea of inductors values ?
I have tried to find any electronic schematics over the internet, without any success.
Of course, I can buy a new motherboard, but I believe this one can be repaired for few euros.
Thanking you in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Frederic Coste, how did you determine that they are "Murata 1210 cms inductors"? It would be great if you can attach your images on here. Thanks for clarifying:-)
完成的
添加一条评论
1个答案
已选择的解决方案
If you are certain that you need the Murata 1210 cms, the datasheet is available right here. Hope this is what you need, good luck.
这个答案有帮助吗?
得分 2
6条评论:
Thank you for your answer.
Please, could you tell me how to post a picture ? Should I use any pictures holder (imageshack...) on the internet ?
Concerning inductors, prior to order components, I need to know inductance values. From your datasheet, values goes from 1µH to 580µH.
完成的
You can post the image on here. On your screen, bottom left, you see the orange tab "Images" click on it. A small window will open and it will show you an "Upload" tab. Follow the instructions and once the image is in that small window, you click on it and drag it into your question. You have to be in "Edit" of your question to do so.
完成的
Picture has been uploaded. Obviously, two inductors are damaged.
完成的
Frederic Coste, sorry, I can not seem to find the pictures:-)
完成的
Frederic what are the L numbers on your logic board? Something like L2 or L4....
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Frederic Coste 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,413
