跳转到主内容
Water is dripping from ac inside home
How to fix water dripping from ac inside the home ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论:
Not sure which type you have, be it a window-type unit or a minisplit. If it's a window unit there's a drain usually from the evap drain pan to the outside. Might be clogged. If a minisplit then there's usually either a drain line (possible clog) or there's a drain line to a condensate pump. Could be clogged line or failed pump. Without more info on the unit it's hard to say
完成的
سبب المشكل هو انسداد منفذ التصريف بالاوساخ
والحل هو :عليك بالتنظيف الجيد بواسطة ضغط الماء
完成的
添加一条评论
2个答案
Hi ,
I received your problem right now that your AC is dripping water inside your room .
Firstly , I used to face this problem and I searched for a way to solve it , and finally I got the way to solve it . On the first step I did , “ it may work with you 95% “ is to go out the house and then going to the AC conditioning from out , and you will find a hose coming from the same ac . You must catch the hose in your hand then use to blow inside this hose hardly , the water will quickly get out the hose and some black dirt with it and wait for one minute then blow again hardly few times .
That was my opinion about fixing you problem and tell me if it work please by sending me a message on instagram , “ @1f0rs “
这个答案有帮助吗?
得分 -1
1条评论:
Problem with this is if you blow into the drain line from outside, you're blowing the clog back into unit. Might drain for a bit but is likely to clog back up. If there's a drain line to outside that is clogged, best to either use a wet/dry vac and suck the clog out, or blow it out from inside. Then the clog gets completely removed from the line and can't re-clog down the line
完成的
添加一条评论
The cooler is dirty
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Navreet Singh Randhawa 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 81
总计 1,318
