跳转到主内容
The Logitech VX Nano is a wireless laser mouse designed for notebook computers. The mouse includes a USB receiver that can be stored within the mouse or inserted in a computer or laptop’s USB port.
Left Mouse Button double clicking?
Does anyone know what causes or how to fix the mouse button double clicking? It is as if when ever I am trying to either press and release or press and hold the button down that it randomly releases and presses again, making single clicks like double clicks and messing up any dragging action.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
This issue is very common across all mouse devices. The cause is the Omron micro switch. Especially nowdays, when they are produced in china. Older Omron switches, made in Japan were much reliable. With novice soldering skills the switch can be replaced, but with enough dexterity they can be fixed by removing the cap and cleaning the contact surfaces. All versions are temporary solutions, the double click issue will return with time.
完成的
添加一条评论
2个答案
已选择的解决方案
So I followed the guide on how to replace the mouse wheel just to know how to take the mouse apart. I cleaned the mouse very very thoroughly and that fixed both my sluggish mouse wheel and also my double-clicking problem! :)
这个答案有帮助吗?
得分 0
添加一条评论
If your left mouse button double-clicking is causing issues, try adjusting the double-click speed in your mouse settings or clean the mouse to remove any debris. If the problem persists, consider updating your mouse drivers or testing a different mouse to rule out hardware failure. As a quantum expert, I recommend checking the mouse on different systems to ensure the issue is not system-specific.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Penny Stacey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 165
