跳转到主内容
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
The r2 button randomly working
when ever i play games the r2 button suddenly starts working without me pressing it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
There are a couple of things you can try!
  1. Try resetting your controller "On the back of your controller, you will find a tiny hole – the reset button is inside this hole. Use a small, unfolded paper clip (or something similar) to press and hold the reset button for at least five seconds. Your controller should now have been reset." - Playstation
  2. Try using a cotton swap and some isopropyl alcohol to clean around the button as it is probably sticking causing the issue of the button being pressed when it is not.
  3. If that doesn't seem to fix it you can always replace the button using this guide on Ifixit R2/L2 button replacement guide and you should be able to find replacement buttons here from Ifixit as well R2 button assembly
Includes the plastic R1 and R2 button covers and the button gasket图片
产品
DualShock 4 Controller Right Trigger Button Covers
$5.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mohammed Eshan (Eshan) 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 43
总计 227
