跳转到主内容
加入维修社区 - 创建账户
2020年末13寸 MacBook Air 的维修指南、手册和故障排除帮助。获取自己维修 2020年末13寸 MacBook Air 所需的一切。
Water damage from underneath
I placed my MacBook Air M1 on the floor and left it for couple of hours. There was some other leakage nearby causing some water accumulation underneath the MacBook Air. MacBook was not exactly floating on the water but there was significant amount of water on the floor. I would say I might have cleared that amount of water with 3 to 5 bounty kitchen paper towels. The system is working fine, keyboard is working, sound system is working, trackpad is working and screen is working too. I tried to find online if there was any "liquid contact indicator" inside the system but couldn't find any. Also I didn't happen to encounter similar situation as mine online (water entry from underneath). My question is should I be worried?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Ignorance is bliss! What you don’t know can’t hurt you.
I personally don’t agree with that! As such I would want to know!
Time to pop off the bottom cover and look for the signs of liquid damage. I haven’t worked on this series of Air yet so I can’t tell you if Apple is still using markers or not. They are round white dots which when wet turn pink/red.
Review this guide to help you get the cover off and what yours should look like when compared MacBook Air 13寸 2020末期 主板更换
这个答案有帮助吗?
得分 2
2条评论:
I did open the bottom immediately to check the depth of damage. Inside everything seemed fine and unbothered. it was like there was no water contact at all.
that's why I was looking for the liquid detection markers to be 100% sure. I didn't find any markers in there.
完成的
@jamie56610 - Then you should be fine!
完成的
添加一条评论
@jamie56610 After removing the bottom cover check the LCI's. These are no longer round white dots which when wet turn pink/red. They are black, and liquid contact is only visible with the use of a UV light. LCIs appear black under normal light and glow blue when highlighted with a UV light.
Use this for the location
and this for the how to check MacBook Air 13 Late 2020 LCI That way you can be 100% sure :-)
这个答案有帮助吗?
得分 1
2条评论:
thank you so very much!
完成的
@jamie56610 you are welcome. You know that you were most likely lucky but it's always good to verify. Best of luck to you and welcome to iFixit.
完成的
添加一条评论
添加你的答案
Jamie 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 32
总计 607
