跳转到主内容
Where are LED lights hidden and how to reset SMU switch internally
I have this mac that won't power up and wanted to at least check the LED lights and hit the internal power switch. However, the LEDs seem impossible to find, I read somewhere that they were hidden under the right speaker but I did not find them.
Does anyone know where to look for the LEDs and an internal SMU switch to try to force a restart on this model? This is the iSight so the insides are deliberately obfuscated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
@ mayer, are those it :-)?
这个答案有帮助吗?
得分 2
1条评论:
You found it!
完成的
添加一条评论
最有帮助的答案
Sometimes those LED lights are on the logic board just to the right of the RAM slots, covered by a piece of black electrical tape that extends up from the bottom edge of the logic board.
这个答案有帮助吗?
得分 2
3条评论:
Miraculous! Nobody has been able to find these! Thank you so much for both your answers because they're so small, I don't think I would have recognized them even if I had found them accidentally.
完成的
Since you both clearly know this computer inside and out ... do you know where the PMU button is? It's supposed to be on the logic board, a small black button ... has anyone seen it?
完成的
I think that black button is only on the older models....:-)
完成的
添加一条评论
添加你的答案
blake 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,603
