跳转到主内容
加入维修社区 - 创建账户
Green light keeps blinking
I had a problem with the volume down button so I disassembled my ipod and used contact lenses liquid to clean it. My ipod had had a really close contact with coffee some year ago. When I put the device back together. The green light started flashing when I switched my ipod off. Any ideas why it is so? And whether the battery will get flat quicker?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I am not sure about having used the contact lens cleaner. Most of the time it contains things like boric acid,sodium or potassium chloride, and multiple other conducting preservatives. I recommend that you once more disassemble your iPod and clean it using this guide after that change your battery as well. That way you will not have to worry about it later. Reevaluate for further damage, if any. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
lakowalik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,032
