跳转到主内容
加入维修社区 - 创建账户
Sony Bravia 32" LCD 电视的维修信息。发布于 2008 年。型号:KLV-32T400A。
Tv will be automatically off
TV it will be automatically off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@santoshull69133 what is the exact model number for your TV? What have you checked? What have you tried? Explain to us exactly what happens. You chin your TV on and it turns right back off? Does the power LED blink? Any specific code?
完成的
添加一条评论
1个答案
Firstly, check if you have unknowingly set an automatic shutoff timer in the TV settings. If that's not the case usually this symptom is indicative of faulty capacitors on the mainboard or power board of the TV at least with Samsung TV's. I suspect similar symptoms could occur on Sony TV's as well, If you're comfortable with doing so, you can open up the TV and check for any bulging capacitors on both the mainboard and the power supply board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Santosh Ullagaddi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 205
