跳转到主内容
加入维修社区 - 创建账户
ASUS Q405U 是华硕于 2017 年发布的一款笔记本电脑。它搭载英特尔第八代处理器,运行 Windows 10 操作系统,并具备多种连接功能。
Won't turn on
The notebook not coming on.
When the AC power cord is plugged in the charging light comes on & it's a constant white light. (which means the battery is charged 95-100%)
But when you press the power button it flickers one time and doesn't come on. Also, the charging indicator will flicker off and then come back on as a constant white light after a minute.This is while plugged in.
When the AC power cord isn't plugged in. The power indicator flickers and nothing comes on.
Can someone help me ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
does your charger show any signs of wear or have a loose connection?
if not, does the charge port on the laptop feel loose?
由完成的
No there's no loose connection. The power cord is in great condition. Nothing feels loose near the port
由完成的
添加一条评论
1个答案
已选择的解决方案
@cassandradover Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
This "power indicator flickers and nothing comes on" sounds like a bad battery. Get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. You will also have to check the switch as well For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
2条评论:
Okay when you say remove the battery. Do you you want me to open up the laptop and disconnect the battery?
由完成的
@cassandradover if you can. Use this guide ASUS Q405U 电池更换 to get to it. Now you are already half way there and it might be a good idea to do the ammeter checking, to see if our battery still draws a charge. If not, I'd replace the battery anyhow,
由完成的
添加一条评论
添加你的答案
Cassandra Dover 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 391
