跳转到主内容
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
Why does it only work on a charger?
my psp go is not turning on and the charging light wont come on either....only when i plug the charger into it and play it will turn on ........if i remove the charger it turns back off.....help pplzzz
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
jahtav, sure sounds like a bad battery. It appears like it does not hold a charge. Of course, make sure that the contacts are clean etc. Follow this guide to change your battery. You can get a new battery from here Sony PSP Go Battery as well as many other places. Once you replace the battery, and it still does not charge, you can check the fuses on your logic board. Check those for continuity with a multimeter. Hope this helps, good luck.
Replace a model LIP1412 battery compatible with the Sony PSP Go game console.图片
产品
Sony PSP Go Battery
$19.99
这个答案有帮助吗?
得分 2
添加一条评论
Use the spare chager
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jahtav 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 6,767
