跳转到主内容
任天堂 3DS 的升级版。它拥有更大的屏幕、更长的电池续航时间、更高的像素密度和更好的设计。
Can I replace the touch screen LCD but not the digitizer?
Hello; I’m planning on ordering a new touch screen LCD for my 3DS XL, yet I’ve come across a problem: it doesn’t come with the touch screen. Is it possible for me to use my old digitizer (which I believe controls touch, correct me if I’m wrong) with a new screen? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@bentc yes you can, but it's a PITA. The touchscreen is glued to the LCD. Use this guide 任天堂3DS XL触摸屏的更换 to remove the display. Then you will have to "peel off" the digitizer. Use something like an exacto knife or similar and cut along the glue line between LCD and digitizer. Just don't break your screen......
Since you have not yet ordered a replacement, check the difference in cost between a complete display assembly and just a LCD. If the difference is not too much, consider purchasing the complete display. Saves you headache and time and almost guaranteed to work vs having to mess with the digitizer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bent C 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 298
