简介
为了更换任天堂3DS XL的触摸屏,您需要先拆下主板及其附带的部件。本指南将帮助您快速更换触摸屏!
你所需要的
从右下角开始,将撬棒的平头插入触摸转换器和LCD显示屏之间,然后轻轻地将触摸转换器触摸屏从LCD显示屏上撬开。
将撬棒插入两块零件之间的右上角,并将触摸数字转换器从 LCD 显示屏上撬开。
如需重新组装您的设备,请按相反的顺序执行这些说明。
66等其他人完成本指南。
由衷感谢以下译者:
100%
Limpid正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
27指南评论
what if you need to replace the screen on the top housing? what is it called.
kerriereed - 回复
Is the bottom LCD screen of the Nintendo 3ds xl, the same as the one in the NEW Nintendo 3ds xl?
Looking for what part to buy.
markknobel - 回复
Bit old, but did you figure out the answer which to buy?
White -
Very detailed and easy to use step by step thanks. However, after reassembly after I switch the power button on it starts and then a flash and it trips out? Obviously a fault somewhere but not sure where to start.? Any thoughts appreciated.
Pete Mason - 回复
That's to do with a part this tutorial skips: you need to put some insulation between the new screen and the motherboard. That's what that orange film is on the back of the screen in the photos. When replacing, you can easily (carefully) remove that film and stick it onto the back of the new screen, no problem. Or you can put some other sort of adhesive to create some insulation between the screen and motherboard. Hope this helps.
