跳转到主内容
加入维修社区 - 创建账户
Compaq CQ57 系列笔记本电脑的支持信息。
How to fix Boot device is not found?
My laptop jst pop up with this massage of boot device not found
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
Hi @katrolmatlou
What OS is installed on the laptop, Win7, Win8, Win10,
Linux etc?
Can you hear the HDD spin up when the laptop is first turned on?
Is the HDD being shown as being detected in BIOS?
由完成的
If you can give us a look into what you see when booting we can give a better diagnosis. Follow this guide to help us give a better diagnosis.
在已经存在的问题里加入图片
由完成的
@jayeff Win8 is unlikely. It's either 7 or 10 with these. I suspect it probably runs 10 given it was free for anyone with a 7/8/10 license.
由完成的
@nick
Just covering all bases ;-)
Cheers
由完成的
@jayeff Heh, I'm not convinced it's necessarily worth doing from a monetary perspective. But OP can probably get ~6 months or so of extra time with a cheap SSD before the true demise comes. I remember this model so well because it had a motherboard issue 11 months in and nearly went OOW before it failed.
由完成的
显示更多的2条评论
添加一条评论
1个答案
最有帮助的答案
Usually a bad hard drive. Whether or not it's worth it to you given the age of the laptop (and the abysmal nature of it being a modern Compaq where HP dumped their waste components into before killing them and then releasing pure garbage consumer line models to do the same job) is up to you, especially given this laptop will not run W11 and W10 is EOL in 2025. You can get a 500GB SSD that will work for this for $53 if you go through with the repair, so it isn't that expensive; keep the SSD when you retire the laptop. If it's running Win10 with a digital license, download the image from Microsoft using the MCT on a working machine and write it to a 16GB USB drive.
To change the drive on this, remove this cover and use a Phillips #1 screwdriver:
If I remember the CQ56 correctly (I remember the HS parental ultimatum more than the full procedure 😂), there was no SATA connector on the board; you unplugged a cable that connected to the motherboard and then 4 screws to remove the entire caddy. 4 screws held it into the same caddy, you use the same screwdriver. Early models used a bridge connector like the IDE HP laptops and the earlier models like the 2007 DV.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Katrolmatlou 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 33
总计 559
