跳转到主内容
加入维修社区 - 创建账户
于 2020 年 11 月发布,PS5 主机拥有大幅升级的视觉效果和极具创新的 DualSense 手柄。其科幻风格的黑白配色方案与 PlayStation 以往的设计截然不同。
Ps5 weird shutdown issue... plz help!
A PS5 I'm working on is having a weird issue I haven't seen before. When you power it on it'll run for anywhere from a minute to 10 minutes perfectly, no video issues or anything. The it will blank out with a long beep only heard thru whatever tv it's plugged into, then immediately power off.
Power it back on it'll do a quick repair for not powering off properly then boot back up. Then it will run again for a minute to ten minutes then the same thing...
I've done a tear down and no obvious signs of anything burned out. Any suggestions on what could be going on? Anything to point me in a direction of a chip to replace or anything would be great.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
11条评论:
Is there a way to get it into a diagnostics mode ?
由完成的
It sounds like it could be an issue with the Power Supply not functioning properly. Can I also ask what the reported issues with the system was that required work?
由完成的
@jmehnert I could tear it down and swap the power supply. I do have a 2nd non functional digital ps5 I picked up I could salvage from.
I'm off work Sunday, I'll try swapping power supplies and will update with findings.
It's just so bizarre, during the time the system is actually up I see no issues with video or functionality. Then poof screen blanks and a long tone then power cuts...
As far as reported issue, wasn't clear. I received system in semi disassembled state, extremely clean almost new in condition inside and out.. not even any dust in the fan or heat sinks. No signs of liquid damage and the fan spins up fine. I looked over the board, applied new liquid metal and carefully reassembled.
由完成的
@jmehnert I replaced the power supply with a known good one. Still same problem
由完成的
@rguilmette1977 I'm also going to go off on a limb and guess that the fan is spinning fine and the CPU is antiquely cooled?
由完成的
显示更多的6条评论
添加一条评论
2个答案
I would even guess a short circuit somewhere on the board
这个答案有帮助吗?
得分 0
添加一条评论
Sounds like it could be a PSU issue (when it shuts off, what game are you playing etc?). It is hard to tell the exact cause, but you can read the UART error codes by using a UART reader if you have a soldering iron to hand? Here is a guide - https://consoletherapy.com/support/how-t...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rob G 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 14
过去 30 天: 28
总计 808
