跳转到主内容
加入维修社区 - 创建账户
TI-84 Plus CE 是 Texas Instruments 于 2015 年春季推出的一款图形计算器。它配备 2.8 英寸彩色屏幕、USB 接口、应用程序、存储空间以及一块 1200 mAh 的电池。
Why is my calculator flashing validating OS
Why is my Calculator flashing validating OS
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
It keeps turning itself off and back on? The easiest thing to try is holding the reset button on the back of the calculator for at least two seconds.
If that doesn't work then the battery is probably nearly dead. Leave it plugged in overnight and it should start working again.
Unfortunately newer TI-84 Plus CE calculators have trouble charging dead batteries so leaving it plugged in may not work. In this case you can try charging the battery in a friend's calculator, or buy a new battery. If the calculator is under a year old then you can contact TI Cares and they may send you a new battery for free.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Dawn Chapman 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 25
过去 30 天: 96
总计 11,224
