跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
Disc drive cuh-1215a replacement issues
So I just replaced my disc drive on my ps4 for the first time. It's a model cuh-1215a. I got it all installed checked over and tried running it. First game skyrim ran great, so I tried installing Diablo 3 and part way through it started making a grind skip like noise then stopped trying to download. Did that on a couple other disc. Is my new disc drive messed up? Or did I do something wrong or skip a needed step?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@patrickstark since this started after a while, you do want to double check your work. The grinding noise is definitely not good . If you find that you did the job without forgetting a step, replace the drive once more. Try a different vendor as well. Check this guide 更换PS4的光驱 for the steps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Patrick Stark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 11
