跳转到主内容
加入维修社区 - 创建账户
TI-84 Plus CE 是 Texas Instruments 于 2015 年春季推出的一款图形计算器。它配备 2.8 英寸彩色屏幕、USB 接口、应用程序、存储空间以及一块 1200 mAh 的电池。
Part of screen is Grainy
I've tried reseting and it scrolling through the menus. Am I missing something or is it just broken?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Almost certainly a problem with the connection between the flex cable that goes to the motherboard and the etched electronic circuits on the glass (on televisions it's referred to as a TAB error). Unfortunately not repairable; you'll need to replace the screen to fix that.
这个答案有帮助吗?
得分 2
1条评论:
I've never seen this issue before so I'm inclined to believe you're right. However, I think it's still worth re-seating the ribbon cable as a simple troubleshooting step.
TI-84 Plus CE 拆解
完成的
添加一条评论
添加你的答案
Javan Watson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 230
