跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
Replacing PS4 optical drive
Hello,
i have the unrecognized disc error and even a drive wich not spins the cd. tried everything but nothing works so i want to replace the optical drive. i have the CUH-1216B Model with the KEM-490aaa Laser model. Do i get the problem with the married board or is it the model where i dont need to replace the board from the optical drive?
thanks in advanced
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@brando64816 that depends on your drive and what is in it right now. "On 1XXX series models of the PS4, the optical drive daughterboard and the motherboard are paired. If your daughterboard's broken, you'll have to replace the motherboard.
You can replace the optical drive assembly by itself, but the replacement assembly must be compatible with the your optical drive daughterboard."
Check the guide on here 更换PS4的光驱 as well as this video which shows just the ODD drive replacement
If unsure, post some pictures of your ODD. That way we can see what you see. 在已经存在的问题里加入图片
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
PlayStation 4 光驱图片
指南
更换PS4的光驱
难度:
中等
30 minutes - 1 hour
这个答案有帮助吗?
得分 0
4条评论:
Where can i See the Model Number? Did Not Look for that when i disassembled it
完成的
@brando64816 does it have a daughter board or just the small switch board as shown in the video?
完成的
I dont have such a large Board. I just take out the power supply to disconnec 3 ribbon Cables and Then i can take out the Drive
完成的
@brando64816 in that case yours will be like the video. If you listen to what Steve says in the intro, you know that you can just swap the drive.
完成的
添加一条评论
添加你的答案
Brando 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 24
过去 30 天: 97
总计 1,306
