跳转到主内容
The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
84 个问题 查看全部
DS won't turn on after charging?
I recently grabbed my old original DS from home and was happy to see that it still powered on without being charged after several years. Later on, I plugged it into a wall outlet using a GBA charger and watched the orange light illuminate for about a second, and then turn off. Now it won't power on, and the orange light won't stay on even if held in different orientations. I opened it up and saw some black corrosion (I think?) around the bottom of the charging port. Should I attempt to replace the battery or clean the port? Is it fixable without replacing the port completely?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@hunieboy yes, you do want to replace the battery. It may have used it's last bit of energy and now no longer accepts a charge. Anything like this "saw some black corrosion" needs cleaning. I suggest you remove your motherboard and clean it with some isopropyl alcohol. Use nothing less than 90%+To clean it I suggest you follow this guide. It was written for an Apple iPhone 3G but it is still pertinent to your console as well.
After that replace the battery, reassemble and re-evaluate. Post some good pictures of your motherboard before cleaning so we can see where there is any potential damage.
在已经存在的问题里加入图片
Nintendo DS Main Circuit Board Replacement
Replacing Nintendo DS Battery
Nintendo DS Battery图片
指南
难度:
简单
1 - 3 minutes
Nintendo DS Motherboard replacement.图片
指南
难度:
中等
10 - 15 minutes
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hunieboy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 45
