Why Video not visible
Their is not video and audio can be audible
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论:
Hi @shankar330,
What is the model number of the TV?
Can you view the TV menu screens OK?
What is the source of the TV signal - antenna, cable box, streaming device etc?
If it is not an antenna, have you proved that the signal source is OK by trying a different source e.g. dvd player etc or different input type e.g. HDMI, Component video + audio, Composite video + audio?
What have you tried?
由完成的
Their is no vision but their is no problem in audio
由完成的
@sowndaryjayaram you have not told us what you have checked. The no video issue can be related to a bad backlight inverter circuitry. A simple check for that would be to darken the room and turn the TV on. Then use a flashlight and angle the light at the screen on different areas. you might make out some shadows or see s slight grey color. Let us know what you find out.
we need the exact make and model etc.
由完成的
Black screen on tv but audio track is working
由完成的
@vincentpaulraj you have not told us what you have checked. The no video issue can be related to a bad backlight inverter circuitry. A simple check for that would be to darken the room and turn the TV on. Then use a flashlight and angle the light at the screen on different areas. you might make out some shadows or see s slight grey color. Let us know what you find out.
由完成的
添加一条评论
