跳转到主内容
加入维修社区 - 创建账户
型号 A1224 / 2009 年初 / 2.66 GHz Core 2 Duo 处理器
How do I fix black screen?
Here are the symptoms:
-When you press the power button, the screen flashes white twice, then stays black. Otherwise, everything else starts up normally with the chime and hard drive sounds, etc.
-Shining a flashlight to the screen shows it still works (just no backlight?)
-I've reset the PRAM, no go
-I've replaced the inverter board but that didn't work
-It does work with an external monitor attached
I am currently running an extended Apple hardware test to see if it brings up anything specific.
Could something on the logic board be bad?
Bad CCFLs?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
The hardware test did not find anything. Bummer.
由完成的
添加一条评论
1个答案
已选择的解决方案
It's the screen connection to the board, screen or video card
Here is the screen guide, take it apart and check the screen connector, if nothing, try a a screen
iMac Intel 20" EMC 2266 显示屏面板的更换
If not, it's the video card or logicboard(I think this model has a MXM card)
I do not know much about the video card built onto the board or a seprate card, but I know this, if it's a ATI(AMD now) or NVIDIA, it's probably on a separate board, if it's intel, no, on the logicboard itself, you will need to take your iMac apart to know for sure about this
Here is the GPU swap guide
iMac Intel 20" EMC 2133 和 2210 显卡更换
iMac Intel 20" EMC 2266 显示屏面板图片
指南
难度:
中等
iMac Intel 20" EMC 2133 and 2210 显卡图片
指南
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 0
1条评论:
thank you nick, i really appreciated you, its also solve my problem
由完成的
添加一条评论
添加你的答案
mike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 2,715
