跳转到主内容
加入维修社区 - 创建账户
iOpener 是一款隔热、保温袋,可在微波炉中加热,用于将热量传导至 iPad 或类似设备边缘的粘合剂上。
Can cold temperature damage it?
Since there is a special liquid in it, can it be frozen? If so, it won't be damaged? I am afraid, because if i order it, it will be stored in parcel machine, which is located outside where is cold.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@lankerst how cold is cold ;-) ? Excellent Question
由完成的
添加一条评论
2个答案
最有帮助的答案
No, it won't damage the iOpener. The iOpener is like an icepack/hotpack.
这个答案有帮助吗?
得分 2
1条评论:
@jri_creator is about right. The iOpener contains Glycerol. So let's say iFixit had the glycerol mixed with water at a common 64/36 or a 2:1 solution, the freezing point will be in the -40 deg C (-40deg F :-) region. Even then it will not freeze but turn into a very thick and viscous liquid. Also, there is minimal expansion only, so the risk of rupturing is low. Check it out.....:-)
Ind. Eng. Chem. 1925, 17, 9, 924
Publication Date:September 1, 1925
https://doi.org/10.1021/ie50189a017
由完成的
添加一条评论
Extreme temperatures can destroy anything I will comment my real answer on this in a moment
这个答案有帮助吗?
得分 0
1条评论:
Yes most likely but only VERY cold or warm temperatures
由完成的
添加一条评论
添加你的答案
LanKerst 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 30
过去 30 天: 52
总计 506
