跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
20 个问题 查看全部
Missing connector on power ribbon cable replacement
I'm trying to replace a power ribbon cable in an iPad 2. It came apart just fine, but I'm now trying to reconnect the button cable connector to the component board, but it seems that my replacement cable is missing the connector to do this?
Above is the component board, with an annotation pointing out where the button cable connector should be connected, and below it is the replacement button cable connector, which appears to be missing the connector to the component board.
This is the battery cable connector as shown on step 53 of this guide.
Is there something I'm missing? Any chance I've accidentally ordered the wrong replacement cable? Any help appreciated, thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Can you add a picture of the two connectors, old and new, side by side? That should make it easier to compare.
完成的
@dadibrokeit just updated, I don’t know where the old cable went, but I’ve pulled an image from the guide for reference instead
完成的
添加一条评论
1个答案
@looks like the cable that does not fit is for a iPad 2 Wi-Fi 16 GB (EMC 2560) like this one iPad 2 Wi-Fi 16 GB (EMC 2560) Volume and Power Button Cable whereas the one that should fit is iPad 2 Volume and Power Button Cable for a iPad 2 Wi-Fi EMC 2415
Double check the EMC number engraved in the bottom, back of your iPad so we can figure out what the right model is :-)
Replace the power and volume button cable in an iPad 2 and fix an unresponsive power or audio button. This assembly includes the internal button switches for the power, volume, and mute controls. The external button covers are not included.图片
产品
$24.99
This ribbon cable contains the internal switches for power, volume, and muting and is compatible with the iPad 2 Wi-Fi 16 GB EMC 2560.图片
产品
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mjesticfalco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 47
