跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
Bootloop after battery replacement
Hello, I recently replaced my battery and after doing so my phone became stuck in a bootloop. I tried restoring via iTunes but it gave error code 9. I looked at other posts on this forum and assume I broke a resistor I would like to try resoldering it but I can't find the damage. It also keeps popping out and another flex cable for my atenna (I think) also keeps popping out. Pictures added below.
Battery:
Wifi/BT:
Any help would be much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hello, could try to disconnect your earspeaker flex cable and try reboot the phone? It is very common and easy to damage the proximity sensor that is on that and cause boot loop.
这个答案有帮助吗?
得分 0
1条评论:
Hi, unfortunately that isn't the problem the cable from my earspeaker isn't connected since I replaced the screen but didn't put over the speaker yet.
Thanks for your reply
完成的
添加一条评论
I had a similar issue after a battery replacement once. The bootloop can be frustrating. In my case, it turned out to be a loose connection inside. I had to double-check all the cables and make sure they were securely attached. Also, try cleaning the connectors with some isopropyl alcohol if you can.
这个答案有帮助吗?
得分 0
1条评论:
Do you remember where the loose connection was? Battery flex? I will try alcohol asap. Thank you for your help.
完成的
添加一条评论
添加你的答案
Bermt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 336
