Power ON starting booting problem
My laptop not able to power ON, it is not getting started, not booting
Verify your adapter is good either by using it on another computer or measuring the voltage on the plug. Did you try it with the adapter plugged in? If so, try it again after removing the battery. If it still does not show any activity, then you have a problem with the computer that will involve disassembly. It may be as simple as a broken power connector, or as serious as a bad motherboard.
这个答案有帮助吗?
Dell Vostro 1520 comes on to password after password won't boot up to dashboard
这个答案有帮助吗?
why didn't you start your own thread?
Idk but my computer powers on just doesn't boot up to dashboard dark screen after password until shuts down
Start with a hard reset: remove the battery and charger, hold the power button for 20–30 seconds, then reconnect only the charger and try turning it on. Check the charger LED—if it turns off when plugged into the laptop, there may be a short on the motherboard. Test with a different charger if available. Remove and reseat RAM modules and try booting with one stick at a time. Also inspect for loose components or dust. If there are no lights or sounds at all, the motherboard or power jack may need repair.
这个答案有帮助吗?
Start by performing a hard reset: remove the battery and charger, hold the power button for 20–30 seconds, then reconnect only the charger and try powering it on. Check the charger indicator—if it turns off when connected to the laptop, it could indicate a motherboard short. If possible, test with another charger. Remove and reseat the RAM modules, and try booting with one stick at a time. Also look for loose parts or dust buildup. If the laptop shows no lights or sound, the issue may be with the motherboard or power jack.
这个答案有帮助吗?
The desktop shell (explorer.exe) is not loading—that only happens after successful authentication. Assuming the auth is successful.
1. Start Explorer manually
• Press Ctrl+Shift+Esc → Task Manager.
• Go to File → Run new task.
• Type explorer.exe → press Enter.
• If your desktop appears, the shell itself is fine — it just isn’t auto‑starting
Press Win+R****, type ``regedit***``, and navigate to:
Look for the value named *Shell***.
Make sure it is set to: *explorer.exe***
If it’s missing or has another program listed, change it back to ``****explorer.exe``.
If it doesn't open, the file may be corrupt.
Open a CMD or Powershell prompt as admin, run CHKDSK C: /f
the open it again and run SFC /scannow
both of these may take a long time. If SFC can't fix some files, run
DISM /Online /Cleanup-image /Restorehealth
You must have inet connection for that. It may also take a long time if it has to dnld files.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 41
总计 381
3条评论
@anilkumar58828 does the power LED turn on? Any of the other LED's turn on? Does it give you any sign of life?
由 oldturkey03 完成的
that's nice. Now tell us something we didn't know - like everything you hear and see when you turn it on. We do not use cryrstal balls.
由 bill 完成的
No LED lighting when switching ON
由 Anil Kumar 完成的
