跳转到主内容
Repair information for Kobo's Aura HD 6.8-inch e-reader (model N204B).
3 个问题 查看全部
I think my battery is starting to fail?
The life of my battery between charges has been slowly going down, and now it only lasts a day or two. Does anyone have any experience replacing the battery in this device?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi @susan44228
Here's the ifixit Kobo Aura HD Screen Replacement guide that will help you to gain access to the battery so it can be removed/replaced.
The battery is glued in place as can be seen in this video for a same brand, different model tablet. (go to 5:00 minutes → into the video to see what they did to remove it).
A better option is to get a syringe and fill it with Isopropyl Alcohol 99%+ (available from electronics parts stores) and run a line of alcohol along the edges of the battery to help soften the glue then gently prise the battery up a bit with a pry tool (examples only) and then add some more alcohol lifting the battery more each time etc, until it can finally be removed. Clean off any residual glue and then perhaps use appropriate thickness i.e. thin, double sided adhesive sheet or tape strips (you cut to size) to hold the new battery in place
Replacement batteries are available online. Just search for Kobo Aura HD battery to find suppliers that suit you best.
Remember try not to puncture the battery when removing it and to dispose of the old battery responsibly ;-)
Assorted prying tools for all types of enclosure opening, cable unhooking, digitizer removal and more. A complete set of opening tools all in one kit, perfect for electronic repairs. For professionals and beginners alike.图片
产品
Prying and Opening Tool Assortment
$9.95
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
ebooksgirl 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 63
总计 1,218
